1 - 11 of 11 Posts
Hi i am new on hear i have a ford focus 1.6 sport 2011 limited edition . Please can some give me the max towing load in kg tried looking on some sites but can't find my car .I am not tecey minded, so a nice simple answer please. Also it is a petrol engine if it makes difference with the towing weight. thanks in advance.
Older Megger
Have a look in your registration Document, Under section 4 (vehicle details) line O.1 gives the max weight you can tow.
Hope this helps.
Lots of variables with the towing weight.
Its recommended to only tow 85% of the cars unladen kerbweight. Unless the max limit
is less than that.
Petrol engines dont tend to tow as well as a diesel engined version.
The cars loaded weight may decrease the max tow also.
With my car i can load the car to 2200kg or tow 1800kg, but i cannot do both. The cars
gross laden weight (car and trailer combiined) is less than my cars max limit..
What are you looking to tow?
You need the cars kerbweight and max tow weight (section O. on your V5C).
Also on the car there will be the chassis plate which will state the gross vehicle weight.
also, you need to check if you are allowed to tow the weight you want to, if you passed your test after 1997, you may need to do the trailer test...?
Lets start with the weights on the car, what does your log book (V5C) state in
section O. And what does it show for the Mass in service section G. and
the Maximum Mass F.1.
Did you pass your test before or after Jan 1997?
I past my test 1990
section 0- 1200
section g-1375
f 1 -1820
Section O is the most useful to yuor question. - it means max weight of the trailer towed must not be more then 1200kg.
Section F is the max your car is allowed to weigh, at any time, i.e loaded with paseengers and luggage. If towing it includes the trailer nose weight of 50-75kg.
Section G is your car in running order. Its suppoesed ot include fuel and driver, but here semms to be some confusion about this.
here should also be a plate on your car (usually in the drivers door opening) this wil also show the MTW Maximum train weight.
For example on my Mondeo
Max mass = 2025kg (plate on car & V5 )
Mass in service 1496kg
Max trai weight = 3750kg (plate on car)
Max tow weight = 1800kg (V5)
From the above you can calculate
Max weight of passemgers & luggage = 2025 - 1496 = 529kg or 454kg if towing
Max weight of triler if cr is loaded ot maximum.
3750-2025=1725kg
But 75kg of the trailer is loaded onto the car via the hitch so max weight of trailer is 1725+75kg=1800kg.
As you can see for my car I can tow the max trailer weight with the car also fully loaded. It is not always the case.
Max tow weight
Section G
As above the caravans gross laden weight or MAM or MTPLM must be a maximum
of 1200kg.
Also check the chassis plate on the car, the gross train weight which will be the biggest
number on the plate and approx 3060kg If its less then 1200kg maybe with a car
thats not loaded to its max.
What does the chassis plate show?
Gary i disagree with your figures, your moving the 75kg from the vans weight to the
car, but your not adding that onto the cars gross weight. The 75kg does not just
vanish.
Simplify the figures, Car loaded = 2025kg + 1800kg trailer = 3825kg.. 75kg over your limit.
The tow hitch 75kg load would put the cars gross weight at 2100kg. Your adding 75kg
to the towhitch and rear suspension. It would be like someone standing on the towball
but not increasing the cars weight.
Its a surprise how much weight 4 adult passengers and a small amount of luggage adds
to the weight. I wanted to take the FIL's mobility scooter on holiday with us and thinking
the estate can carry 1/2 ton. 5 up and some luggage soon eats into that.
1 - 11 of 11 Posts
