my 70 plate transit connect is using a lot of coolant, I have topped it up twice in 12000 miles. Ford tested it & said it’s ok.
Do they use this much coolant normally?
No, the coolant should stay at the same level for years and years.
Where is it leaking from?
Must be going somewhere.
Leaking but only at certain engine temperatures or at certain speeds etc?
Boiling away because the cap is not sealing properly?
Sometimes you can see a stain where its been leaking, how much is it losing over days/weeks or miles?
How much did you topup over 12000 miles? Does it drop quickly once refilled? Not overfilling?
