Seeing I have now recieved my Blue Lockwoods I decided to convert my trip and door switches over to blue.
Im not too bad with soldering so rather than use flattened 3mm LEDS I used SMD LEDs instead. This was suprisingly easy.
All you really need is a fine tipped soldering Iron and just tin the end a little bit and then touch the existing SMD on one side to loosen it from the board. Then use a pair of tweezers to remove the SMD from the board while loosening the opposite end with an iron.... if you have done a clean job you should end up with just a couple of pads.... add a little bit of solder to the pads.
Then use the tweezers to hold the SMD so one side is pointing down at about 45 degrees (or less). lightly touch the pad with th iron to melt the solder and then touch the SMD on the pad. This should then fix it to the board, after this you can push the SMD down. I believe the anode side is the side with the notch on one corner but just follow the orientation of whats there and you SHOULD be ok.
