1 - 15 of 15 Posts
My car has lacked power the last couple momths & been hungyry for fuel!! Took it to my local ford garadge they plugged it into the diagnostics machiene & said its one of my EGO Sensors? there not sure witch one as there are 4 of them & they are £80 each from ford!!! :headshake: Where are located & can i get them cheaper & sort out myself? anyone else had this problem?
I Love Diesel
HEGO aka O2 aka LAMBDA sensor. theres a sticky on them in the transmission/fuel/intakes forum. surprised they cant pin it down a bit closer really, maybe they want you to buy four. :loopy:
Yo
They are talking out of there arses! For a start there are only two, one on the front bank downpipe and one on the rear, and if they plugged their diagnostic equiptment in it would tell them exactly which one was faulty!
Take it to a different garage!
thing is the owner is a very good friend of me & my dad so i wudnt of thought they wud try to rip me off!! didnt cost me anything to plug into the diagnostic machine
what year car is is? later cars have upstream and downstream O2 IIRC.
its a 99 V plate mate, they said something bout upstream & downstream! so how easy are they to change myself?
Discussion Starter · #9 ·
MONDYMANv6 said:
they are not that bad to change , just fiddley to do , you can miss them , and there is only 2 :L
So whats this upstream & downstream all about then mate? where can i get some cheap???
late V6 mk3's have 4 sensors, as dave v6 said. They are used to measure catalyst efficiency so one is needed each side of the two cats.
Cheap sensors are a false economy, they dont last as long and pay a vital role in correct air/fuel ratio and catalyst life.
ST200 baby
thats a good point , i thought he had a MK2 but if you say a mk3 as 4 then i did not know they had 4 either , lean somthing each day :D
ST200 baby
what have you got , mk2 or mk3
Yo
He has a mk2 (as it is V reg, and I looked quickly at his previous posts!) so it will only have the two.
1 - 15 of 15 Posts
