1 - 10 of 10 Posts
What is involved as I have the loom and switch from the drivers front door and the loom, switch's and motors for the rear windows...
I fit the rear loom and pluged in the switch and motor and feck all happened so I installed the front loom still the rear windows didnt work...,
Can someone please tell me what I am doing wrong...
Thanks for any help..
LED Extraordinaire
Easy.... remove the seats, handbrake consol, carpet and the plastic trims out of the car then its a case of unpluging the floor loom from a few plugs and laying out and pluging in the new loom :) , in true haynes manual form " refitting is reversal of removal"
should be ok with the L & K reg, i upgraded my old Mk1 L Plate to EW all round with no real problems.
To ensure a hassle free change you will need
Floor Loom
All Looms to front and rear doors as the std Mk1 only has one twist connector on the A Pillar, 4 way EW has 2 each on front doors
All window motors (mk2 are better as they have different motor casings)
Driver side switch
Remove as per post upthere somewhere, there are also earthing points to undo which are secured by 10mm bolts
Discussion Starter · #10 ·
Thanks for the help guy's I now have to wait for another MK1 to comin to were my mate work's they crushed the car so all I now need is passenger door loom and Floor loom I have the rest...
1 - 10 of 10 Posts
