Urgent Help Denso navigation system
7565 Views 15 Replies 4 Participants Last post by  kelvinterry
3
Welcome dear friends, as I had mentioned in the presentation, I have a navigation system 7 "touch of Denso, which by mistake I deleted the data from the module and now I have no radio, GPS and air conditioning system is not possible to know the temperature etc. ..
this happened because the code introduced a menu that gives access to hidden menus and erased everything. because I went to ford and they have introduced new data through the IDS. but it is not possible to retrieve the data, because the dvd drive is always request a new data cd, cd that the ford is not available to the system Denso, anybody here have this cd / dvd, or know how I get it?.'ve read somewhere that Ford Tech germany has such data.
I'd appreciate your help because now I am deprived of my system, and that is so lacking.
I removed the site where the damn codes was here. solesz.hu not make the same mistake I did.
Thank you all and thank you for your precious help because it was where I found very useful material that has a Ford.
Oscar
1 - 16 of 16 Posts
You need the cd that comes with the 2004/2007 map DVD if you google you can find it on the net as I did or you may get it on ebay remember you need the CD the DVD on its own won't get your software back. if you are really stuck contact me by Email
As a footnote, the CD that contains the necessary information can be ordered, by your dealer, FREE OF CHARGE (To them) from Ford Tech in Germany.
If no luck there, contact KT as the above post...
good day, not clear, says I need a cd or dvd? is the same as the navigation system. I have the 2005-2006 and there is not any data programming, they are referring you to the 2004?
I'm really confused, hehe.
this is the DVD navigation that I have, moreover, is already outdated, after solving this problem have to try to get a 2010.
Good morning, that's right I'm really not possible to arrange such a cd or dvd you say, where do I get? in which the ebay link for it?
you have this cd / dvd?
tks
I have both the CD and the DVD You only need the CD to get your software up and running the DVD is permanently installed in the player usually in the boot under the Cd Multi-changer or sometimes behind the glove box.Not the CD drive at the top of the unit. I can probably Email you the file its not very big for the software and instructions. in English or Spanish. you will need to burn it to a rewritable CD not a CDR.for it to work it takes about 10 mins to install altogether.
The CDS are rare and only supplied when there are firmware changes I got this one of the net. Most a fakes. I say again you need the CD for the software not the DVD.
Please search around the forums as there are many threads linking to a rapidshare download for the update firmware cd image. You need to download this 19mb file and burn it to a blank CD-RW, DVD-R or DVD+R DL and then insert this disc into the mapping disc drive in the boot. This will re-install the firmware for your system and get it working again. This will also be the latest firmware, which will mean you can use any mapping disc 2006-2007 and beyond.
I have the latest firmware thank you its not me thats asking for it mine is 2007.
Ok Kelvin, if you can then send to my email [email protected], I would appreciate the file, I tried to find the link as I indicated the Smjohns, but found nothing. thanks
2
By the way this is the drive that is installed in the glove compartment, which always has the DVD navigation inside, which in turn ua also is not 100% but more important is to recover the data.
I have just Emailed you at 19.12 pm UK time watch out for the Email check your spam folder.I hope this sorts out your problems.
2
Goodnight everyone, I come here to thank you for help and availability, in particular the Kelvin helped me solve the problem I mentioned earlier, is now working correctly as the pictures attached.
you all.
Carlos
It was my pleasure to help.
1 - 16 of 16 Posts
