:BEEP: :BEEP: :BEEP:
Hi all really need some info ASAP. Just fitted a recon'd IMRC from Nick, and after 2 1/2 hours coupled with a calamity of catastrophic tool failures and hardly any fingers left, I put it all back together and took it for a spin. Didnt notice that the temp was on red until half way up the dual carriageway and I did notice that the car struggled to get to 4k intitially. Pulled over and had a look. Water res was bubbling over. Let it cool down and I limped home. Put all my heaters on to take some heat out of the bay but this eventually went cold. By the time I got home (mile away) just checked the res and its nearly empty. My gut feeling is that the HG has gone. Would any of my work done this morning have contributed to this happening? I only went as far as taking the throttle body off the UIM - even that was a frightening sight!!
Any advise or additional checks I could do would really be appreciated as I'm starting to ask myself if i'd put things back together properly.
Also, what would have happened if the cable from the IMRC had come away from the ball housing that it clips to down below? Could this have done it??
Ta (need a volunteer to tell the wife)
Dougie
Dougie
