1 - 6 of 6 Posts
Guys
Just got a new keyfob and re-programmed it - Doors open and lock fine.
But went to start the engine and seems to be immobalised - Any Ideas?
The red light on the dash starts flashing and i get nothing from the engine at all ie turn the key and absolutly nothing happens.
Oops sorry i did get the engine to turn the first time but it would not start
Ta :evil:
MEG Admiral
did you program it yourself? the chip inside the key needs programming to your car. its only the remote side you can program, get your old key and hold it near the ignition while you try to start the car if it works then you need to get the key programmed by ford or some locksmiths do it. about £80 or there abouts i think it is :L
Resident Old Fart !
Or just swap the transponder from your old fob over to your new fob ;)
Resident Old Fart !
DIEHARD said:
Done this - worked a treat Cheers :L
:L :L :L
1 - 6 of 6 Posts
