Iv a late 2000 ghia x.
Starting problem (electrical im sure), the battery is flat, but i can jump start it. i charge the dead battery for 5mins, remove jump leads and the engine runs for several minute before it gets alittle rough and then dies. Needs jump started again to get going.
When i try and turn over engine with key, i get ticking noise from starter motor, but no engine turn over at all.
I thought starter motor gone but that wouldnt cause it to cut out again after a jump start.
Three problems i definately have are 'Fuse 30' Heater blower/instrument panel illumination fuse keeps blowing (with correct amp), maybe linked my SATC heater control dials dont work and my Dipped beam headlights dont work, only flickering on inital switch turn on.
Any thoughts?
Do relays die and need replacing and how do you know?
Any thoughts?
