The trouble is if it has slipped has any damaged been done, i was working on a mgf few weeks ago doing a full rebuild new pistons big ends etc etc due to a none starting prob, it turned out the roll pin that locks the cam sprocket in place had slipped and kinked a inlet and ext valve on cylinder one and just would not go, if this could be the same type of prob maybe?Captsensible said:Hi, the reason that i want to check the timing, without a complete stripdown is because i thought my chain(s) had snapped.
what happened was i was getting a juddering from the car as if it was misfiring, then one morning i went to start the car and just before it fired, there was a crunching noise then the car made a whirring sound,simalier to a snapped cambelt. I have removed the front cover and sparkplugs and the chains look tight and ok also the sparkplugs were not damaged, when i turn the engine by hand there is no tight spots so i thought it must be something else so rebuilt it back up.
When i went to start it, it was turning over but would not fire, so i tried one of the old spark plugs and there waqs a bright spark.
I then took the caps of the battery and found that the first and last cells were dry so filled them with distilled water, i am thinking that the battery may be out its way out but don't really want to take it off the car as i don't want the ecu to be wiped out in case the is a fault that can piont me in the direction of my non-starting.Sorry if this is long-winded
Glad you have sorted your porb, is it still running ok?Captsensible said:Thanks to everyone who replied to my question. I do not know what i have done except change the battery but my car now starts yeppeh.
The only downside is that the car is reluctant to go into reverse gear but will if I press hard on the accelerater.
I did not touch any part of the gearbox,OBTW it's an auto. So am I right in thinking that taking the battery off I have wiped the memory from the ecu and this also controls the gear selection,just a thought if so i shall have to just take it for a drive.
Once again thanks to everyone and also mondyman for the link, it should prove useful when I ever need to strip it down again lol.
