Vehicle is a 56 reg Mondeo TDCi 130 6 speed, 92k miles.
It developed the classic noisy DMF and trashed the starter, so I had the starter replaced and on recommendation I had a new SMF kit fitted, comprising Clutch, SMF and CSC from National.
I immediately had issues with noise and vibration which seemed to come from the clutch area, but only occurred whilst accelerating through the gears and only between 1500 and 2000 RPM.
The work was checked by the mechanic who could find no obvious cause, other than a possible faulty replacement flywheel, so everything was checked and a second kit was installed, same make, National.
Result - exactly the same as before, bad vibration between 1500-2000 RPM, most noticeble when accelerating from 30 mph in 4th gear when the vibration gets quite bad, but goes away when the revs get to 2000+.
Has anyone else had the same kit fitted and had a similar experience?
I am reverting back to a DMF but I am worried now in case I still get the same problem.
