Ford Galaxy Mk3 2004. I have an orange rear fog warning light that only occurs only when I brake, then goes off when I take my foot off the brake, I have checked rear fog lights, rear brake lights, rear lights, and I cannot find any reason why this occurs.
Incorrect bulb fitted or a faulty earth?
I have not fitted any new lamps but earth fault a possibility. I had a similar experience before on a VW Passat when a glow plug warning came up and after checking out all the glow plugs and other things, I ended up 'phoning a VW service engineer and he told me it was a faulty brake light ( strange I thought ) but he was right, apparently it's what VW do, and I just thought it might be the same with the Ford Galaxy.
Problem solved, found a broken brown wire in the cable loom at the rear tailgate next to the hinge.
