1 - 2 of 2 Posts
Dear members,
I'm experiencing wet carpet at rear right passenger side.
At first I thought it was due to water leak from the right taillight but I discovered that water was coming through a hole in the trunk. The hole is circular as I felt with my fingers.
I've attached a picture which shows how a homemade plastic wire is able to reach from outside to the inside of the trunk.
In case you have any pictures of mk4 st. wagon without the rear bumper pls share since I'd like to see how that hole is covered in our models.
Thanks!
Automotive tire Automotive lighting Hood Road surface Motor vehicle
Discussion Starter · #2 ·
Problem solved: a "circular plastic seal" fits the hole and water ingress is thus prevented. It seems that the mechanic who fixed the trunk after an accident forgot at put it back or the seal fell off for some reason :unsure:
1 - 2 of 2 Posts
