1 - 7 of 7 Posts
MEG general
would you guys and be able to help does anybody know the location of the oilpressure switch and the location of the water temp switch on a mk1 2.0 si as i need to change mine as the oil light has stopped working and the temp gauge works when it feels like it
Turbo Boost Me!
Oil pressure switch is on the bacl of the block and the temp sender is on the bottom left of the thermostat housing
MEG general
is the temp switch the one on the bottom of the thermostat housing not the one on the top?
Turbo Boost Me!
MEG general
cheers my man i will do it in the morning. sorry for sounding thick its been one of those days. and my brain hurts
irishghiax
oil pressure switch location :L
sholudn't you be investigating why these don't work, rather than just fitting different gauges? Does the oil light come on when you switch on the ignition? If not, remove the wire off the oil switch, earth it, then turn on the ignition and see if it comes on. If it does, the switch is knackered, (unlikely) and if it doesn't come on, then it'll be the bulb.
1 - 7 of 7 Posts
