Absolutely fed up with my mondeo afters epic catologue of things going wrong.
Decided after hearing the drive shaft munching when turning corners to chabge her,not a bad job split it just before the bearing easy job :headshake:
Got one from our yard,brought it home fitted it bloody end burred so carnt fit the driveshaft nut,remove and throw to one side,
Of i go again back down the yard to remove one from a mondy thats all still in tact,great comes of no problem gets home fits it all great guns,spin wheel to make sure,it bloody locks :( the end nearest the bearing has gone tits up now.
Well now getting well pissed off with the job,so i end up removing the cv joint of the origanal,remove the cv of the other shaft and fit it onto the origanal shaft and at last success.
What a bloody day in the rain was not a happy :BEEP: bunny
Turbo'd ST24
yeah that really bites, im glad you sorted it out, i bet you were really pissed off when you saw the bits werent fitting and then another problem occurs which is really fustration, it makes u want to kick the damb parts but glad you got it sorted out!! :L
