Brake booster/brake servo pipe. Use your VIN on Ford - Catcar.info
Or just get a piece of pipe the correct size from an car accessory/parts store.
Ok thanks, went to a part shop and just bought a piece of pipe, seems to work pretty good!Brake booster/brake servo pipe. Use your VIN on Ford - Catcar.info
Thanks Nicam!MAF answer : no it's not a valid test on the mk3.;disconnecting the maf won't stall the engine.
Thank for the reply Nicam.1-3-4-2 is the FIRING order of the cylinders. Does that make it clearer?
If you've still got the original injectors fitted, they shld be in the cylinders as numbered on the sticker. You can quickly check this by taking pics of the labels on the injectors and comparing the 16-digit hex codes with those on the sticker.
Ok perfect, than it’s all fine!!Correct! Cylinder #1 being closest to crank pulley end and cylinder #4 closest to battery end.
