1 - 9 of 9 Posts
As title.
Does anyone know?
So just normal heating??
I HAD A FOCUS B4 THE MONDEO AND UNLESS WE HAD JUST GOT IN THE CAR OUT OF THE RAIN IT DINT USED TO STEAM UP THIS BAD
SO IS THAT NORMAL WHEN IT RAINS YOU NEED AIR-CON ON TO SEE WHERE YOU GOING
Couch Potato
[quote name=neil s]IF ITS DAMP OR RAININ OUT AND I SELECT ECO ALL THE WINDOWS STEAM UP ANY IDEAS[/quote]
"HI" heat setting will dry things out after a while then you can leave "ECO" button in and returm temp to 22C or 23C (or whatever you prefer). Wtih the AC, I find that it steams up just after switching from on to off (ECO) or vice versa, but generally leaving it set on one or the other it's ok.
P.s. don't forget to press your "Caps Lock" key off, using caps is regarded as shouting on most forums.
1 - 9 of 9 Posts
