Does anybody what the circled thing is and what does it do?
I was thinking about removing the egr pipe for good but noticed that there are 2 pipes on the egr pipe that are linked to the device circled.
On the first pic the device appears to have the pipes joined. Is this ok to do.
EGPD sensor.
its the Differential Pressure Feedback sensor.
It measures the pressure difference across an oriface plate inside the EGR tube. From this pressure a gas flow can be calculated by the ECU so it knows how much to open the EGR valve. You can run with it disconnected but it will generate a fault code.
More info enclosed ( aimed as US market but the same system is used on the mk1/2 Mondeo's )
will the error code cause any running problems.
