Well I changed the turbo yesterday but the new 2nd hand one came apart really easy lol,,, so I decided to try and take the whole manifold off my car and replace with the used one,,,,
Oh how stupid was that hahaha
I had no way of removing the EGR cooler, so I could get access to one bolt that was been blocked by the pipe,, so I decided to split the turbo in situ and just replace that ,,,;;
As you can see in the photo it was practically welded to the manifold hahaha. So you start tapping gently and you get more and more sweary you starting hitting anywhere and everywhere as hard as you can,,,,, well my advice is don’t as things break really easily,; luckily it did move in the end and I’ve replaced no more whistling but I have whooshing sound like air leaking, I also have what sounds like a dump valve noise when I lift off the gogo pedal,,, anyone have any thoughts on what these could be.
cheers peeps.
