hey guys , any one know which wires aer pos and which are neg? for the front door speakers
cheers
Have you looked at the top of the forum where it said read these before postion ?? :whistling:
18-10-04 05:55 PM - Post#482659
In response to gaz812uk
and when you come to fit your new 6x9s your gonna wander which wire is which,easy look at the yellow speaker plug in the door as the letter T across the top of the T is Negative - and coming down the T is positive + this is the same for mk1 and mk2 not sure about mk3 and this is the way the Autoleads speaker adapter plates are wired which fit the mk1/mk2 doors for fitting component size speakers in ?11 ish a pair from hellfrauds Nissan Skyline R33 GTS Spec2
Mondeo MK1 TD Hatch
Ford Focus 2.0 Ghia
Hope this helps :L
no it doesnt sadly coz my connectors had already been cut off when i bought the car,
thanks any way
any one else?
MEG Captain
just wire the speakers up and put something on with a bit of bass in the cd player....watch the cone..if the cone moves out on a bass note your ok..if the cone pulls in on a bass note its wired the wrong way round...info on wiring codes on the plug in the dash can be found here http://www.mirez.co.uk/Radio.htm but it dont list the positive or negatives..plus the wires change colour once they enter the doors.......
