Wont start, when it does cuts out
503 Views 4 Replies 3 Participants Last post by  roysweb205
Hi
I have a 16v 1.8 97/98, it overheated, tries to start off the key but don't, will start with a tow but wont idle, dies at 1500 revs, any advice please, roy.
if its overheated then it may have damaged the internals of the engine, causing it to be tight hence the reason it will not idle.
sounds like you have blown the headgasket when you over heated it which is why it will only start with a tow and also why it wont idle
phil
best thing to do is to get it compresion tested as this will tell wether or not the headgasket has gone
phil
Hi Phil thanks for that I'll try and get it done in the next couple of days, roy
