Welcome to MEG.
When the mechanic says it's better off buying another car.... it is as long as you don't get that problem again. That is one of the most expensive 'common' faults (along with the injectors) but once it's done then the car should be good for another few years. Buying another car means you have the risk of the same issue plus more. At least you will know that with your car the faults have been fixed :L
