I know I'll get shot for posting this here, but I'm not getting much info in the non-mondeo bit, so here goes.
My wife has just bought a Mk4 Fiesta 1.4 16v with 69,000 miles on. The only problem I can see is the engine seems to be over-revving on startup, (upto 2000+ rpm), holding its revs to long on gear change, or as you pull up to a junction and its hot idle is about 1000rpm which I know is to high.
I was told by the previous owner that thay had replaced the TPS and IAC valve and ford had also updated the ECU??
Any advice greatly appreciated!!
TIA!!
Mark.
TIA!!
Mark.
