I manage one part. To IPC go on( bring 12v) to try program the keys and scan for dtc, but then things go crazy. I using IDS with code/incode and go to rfa key programing... After folowing all instruction keys are not able to program into the rfa... Also add key is not succesfuly, as module initilizing , and erase and program a key options.... Now i assume that rfa module is dead and because this i canot program new keys and i dont have stored old keys. If i try to use forscan and go rfa programing i just receve message about lost comunication with eslc..... For dtc i have two which is related for this problem. B10D8 Key less that minimum programmed and U0167 Lost comunication with vehicle immobilizator
