Hi all
I have a 2005 Mondeo 2.0 Tdci 124k on the clock.
Recently the Glowplug light has been coming on and car goes into idle mode then cuts out.
Odd thing is that its normally only at speeds above 65mph and even then not always.
I have tried to make it do it so i can get a grip on what is causing it but so far I have made it do it occasionally but no pattern seems to be obvious.
I can rev the balls of it right into the red line and its fine, drives about town all the time with no problems, has lots of power never misses a beat until its at speed!
I have just done 200 miles at about 65-75 mph and it didn't happen at all.
I have had a error code previously as "PO251 injection pump fuel metering control A cam/rotor/injector"
but just plugged in again and now no codes stored?
Problem is its dangerous as it can happen when overtaking a lorry for example......
EGR valve was replaced 18 months ago after engine management light came on
Any Ideas where to start looking?
Any help appreciated!!!!!!
