Flickering headlights
10K views 10 replies 4 participants last post by  Pichacker
#1 ·
Hi folks,
So now the darker nights are upon us i have noticed that my dipped beam headlights seem to randomly flicker but only when they are cold. After 5 minutes of driving the flicker stops. I haven't noticed the high beam flickering but then the high beam doesn't get as much use.
All other lights seem ok, and i cannot say for certain if its both headlights or just one. I have tested the voltage from my OBD port which with the engine running its a pretty consistant 14 volts. Has anyone else experienced the same or have any ideas? Im tempted to try new bulbs but thought i would ask on here first!
#3 ·
Did it on my previous 57 plate as well - it's a common problem apparently, and Ford do a kit to overcome the problem which is a slight change to the wiring loom at the alternator, but there's no need to buy the kit as it's just a bit of wire with a ring connector. If I can find a link I'll post it.
#5 · (Edited by Moderator)
Lifted from another forum:
The problem is well known to ford and the cause is that there is a high resistance in the battery wiring harness from the central junction box under the bonnet to the b+terminal of the alternator the high resistance from the 7.5amp fuse causes the alternator to pulse and this causes the flickering of the lights both insisde and out and on the dash fords technical service bulletin recommends an additional wire should be installed which takes a new feed direct from the main battery cable on the back of the alternator the bulletin number was TSB 053/2001 Part number for this cable - 1133503 from what i can gather people who have done it themselves say that you should unplug the multiplug from the alternator and pull it up to the top of the engine, splice into the red wire, then solder the new wire on and wrap it up in tape. Then drop it back down and put the ring connector on 'under' the thick red cable connector and reconnect the plug The multiplug is on the alternator, just around the side from where the thick red cable mounts.
The instructions say that the wire should be soldered on about 10cm from the plug, so you'll need at least a bit more than that.
This flickering has been blamed on alternators etc etc so as i said to many before it is common for the ford lights to flicker and this applies to all models basically its up to the person wether or not they do it yet ford never issued a recall just a technical service bulletin stating that should a customer show concern then they were to advise of this new wire otherwise say nothing.
More info from the same source:
After searching it found it covers ford focus including rs and st170 ford mondeo ford ka cougar etc almost every ford model as they are all set up the same way mondeo forums have known about it for a while the st170 forums have also been aware of the issue it seems to cover lots of models including the focus though there is no list of which exact years it refers to fords technical bulletin is generic in that any ford model showing these symptoms and with the customer concerned they are to make the customer aware of this wire and thats basically all it is an £18 piece of wire. i first found the info on the st170 focus forum then again on the mondeo forum in relation to the mk2 and 3 mondeo also on a ka forum ive found similar complaints on smax forums galaxy fiesta etc etc
#6 · (Edited by Moderator)
#10 ·
Be careful. That's a very old TSB and was written long before your vehicle was made.
Applicable to Cougar 1999 - 2000 MY with 2.5L Duratec‐VE engine according to title.
You're right that it's old but I have read a reference to it working on a Mk3 Mondy - obviously this is hearsay but it may be the cause of what was, and evidently still is, a fairly common problem across all models.
#11 ·
I did look at the diagrams for the alternator control and there are apparently subtle differences between the CD132 Mk3 and CD34x Mk4 vehicles.
On the Mk3 the alternator has the following connections:-
Stud - Charge output to battery.
Connector - AltMon
Connector - AltCon
Connector - +12v Feed
The +12v feed is fed from a 7.5A fuse in the fuse box. This feed powers the regulator circuit and is subject to a long run from battery to fuse box to alternator. This is the circuit the TSB addresses by locally linking the stud output to the +12V feed bypassing the fuse etc. This stops the alternator regulator from oscillating.
The two other connections (AltMon, AltCon) go to the engine control module where the output charge from the alternator is monitored and controlled to provide the best charge back to the battery given the current operating conditions and battery temperature.
On the Mk4 (2009) the diagram shows only the main power feed and a control line marked LIN. There doesn't appear to be a possibility of any modifications as previously. Not sure of the validity of the diagram for all variant though. For info the LIN in a bi directional control bus. Data is transferred between the alternator and the engine ECU.
