Hi,
My climate control doesn't seem to be working at the moment so I followed the prodecure in another thread on here to run the diagnostics and read the fault codes.
The diagnostics show an animated display for 20 / 30 seconds then every segement on the display lights up and the unit seems to stay like that until I end the test. Is that the expected behaviour?
If I then use the sequence to look at the fault codes I see 2 of them. Again, from the other post one of them is this:
"U210100 E101 Faulty configuration of the climate control assembly REFER to: Module Configuration (418-01 Module Configuration, General Procedures)."
Would someone please translate that?
The other fault code is 9069 and I can't find a reference to that in the previous post or anywhere else, any ideas?
Thanks,
BraileTrail.
Thanks,
BraileTrail.
