Code P2339 Investigation - Am I On The Right Track
1.8K views 13 replies 7 participants last post by  salta
#1 ·
Hello all, I've been lurking on the site for ages, its far better and more friendly than some I am a member of!
Anyway, I've got a 2002 TDci 2.L Manual 130BHP Ghia X Estate - all the usual trimmings - leather/nav etc.
About 4 months ago it developed the 'white-smoke-limp home mode-tricky starting-throbbing and lumpy under load, 30mpg max, fault'. The car was owned by a friend of mine at this point - he had spent over ÂŁ1500 on bills with the Ford Dealer and a generic mechanic and was at the end of his tether - I mentioned that he might want to take it to a diesel injection specialist but before he did that to rule out any other possible route cause. By this time, he was so fed up that he offered to sell me the car and has since moved on to a newer petrol model.
So, I went through the recent service history and the bills had indeed been eye watering:
new glow plugs and relay
new injectors
another new injector
5 days labour at main stealer rates...
they had diagnosed Fault P2339 relating to Cylinder 3 (which I understand is the 4th to fire) being over it's knock limit. This certainly would explain the limp home mode and the 'throbbing' missfire under load and the white smoke - horrendous on start up but always present - as is the whiff of diesel. Replacing and rotating injectors has not solved the issue so I am suspecting a deeper cause.
So this is what I have done to date:
1/ checked positive and negative main battery cables
2/ checked terminals at battery, starter motor, earths
3/ removed, stripped and cleaned starter motor
4/ checked turbo actuator
5/ checked turbo fins for play
6/ removed inlet manifold - caked to 0.5cm with yucky oily carbon deposits
7/ removed EGR Valve - equally caked with gunk
8/ removed and bench tested glow plugs - ok
9/ tested wiring to glow plugs - ok
10/ removed CAM position Sensor
11// cleaned inlet manifold and EGR - horrible hateful job - almost enough to put me off diesels!
next steps:
12/ replace fuel filter with new one - this car was doing 30k a year from 2006 till 2010 - since 2010 the car has done town driving - the fuel filter on it looks rather old I know Ford say 37k but real world experience has always taught me to change diesel filters on TDCi engines used in town at the same time as an oil change - ie every 6000 miles.
13/ replace CAM Sensor
14/Blank EGR Valve - I have made 2 blanks - one plain one and one with a small hole - I will use the total blank first and after 1000 miles replace with the holed blank - this will keep the emissions light off
15/ examine old fuel pump for metal debris (suspect fuel pump)
16/ run the car for a couple of hundred miles
17/ add fuel system cleaner twice
now, this is where general knowledge runs out and model specific knowledge comes in so I would be grateful if those who have more experience of this car than I do check what I have done so far, is there anything I have missed?
If after doing the above works - do I need to 'clear' the error code to remove the limp home mode or will the ECU learn the new settings with time?
If I do need to have the code cleared at this stage I will take the car to Lawson Diesel in Edinburgh who will test the fuel pump and the injectors on their specialist machine - the only one of its kind in Scotland - if the fault lies with the pump, I'll buy one of their refurbished ones - I will get them to check and recode the injectors.
Does this sound like a good strategy - I'd rather not replace the pump at this stage until I have tried a filter and CAM sensor- do I need to consider the fuel pressure regulator?
thanks in advance and for all the info I have gleaned to date
rich
#2 · (Edited by Moderator)
Hi Rich,
If your car is throwing up P2339 then your next test should probably be a leak-off. Having said that, I think Fordiag can effectively diagnose this from the Combustion Noise Sensor readings. I have a Fordiag and live in Edinburgh if you want to bring the car here.
I think P2339 points to cylinder #2 counting 1234 from the chain case side. See: http://www.talkford....on/page__st__20
Peter
#5 ·
Hi, mines an '02 plate Mondy, same as yours, can you tell me if yours is a front fitted or side fitted egr? Mines a side fitted one-you can't readily see it. Really wanted to know if it's a fairly straight forward job to get to it, as the Haynes manual suggests having to drain the coolant 1st.
My Mondy had P2338 error and limp mode, (cylinder3 above knock threshold) and I cleared it with the ForDiag by recoding injector#2....but now it's just failed the mot on emissions (black smoke)
so I'm looking at cleaning the egr and manifold, and all the advice is for the front-fitted egr type, so will appreciate advice from anyone whose had experience with my type of egr
Thanks,
Nick
#6 ·
Thanks,
Nick
from my experience its never as successful coding just the failed cylinder.
always code all 4 with stone cold engine stopped for minimum 8hrs.
mine varies between cylinder 3 and 4 when I get limp mode.
#7 ·
Also if you recode it will sound like the ends are knocking for a while strange that sometimes when i have coded them they are more noisy than other times i coded them all a few days ago and was really bad sounded like the engine was fooked but after a few hundred miles is better just a bit noisy in the morn and getting better and the thing is cos mines a early monde i cant read the codes so dont no if they have all taken ok.
#8 · (Edited by Moderator)
well Peter has been a great help and very generous with his time and tools. He was kind enough to take me for a run in his fantastic 1939 Jaguar SS as well, a wonderful treat and a huge credit to Peter's dedication, work and expertise.
We ran a code test and Peter identified that it was cylinder 2 (that is 2nd on the block) the 4th cylinder to fire that was playing up. The mechanics had read it as cylinder 4 on the block and had charged my friend for replacing it when there was nothing wrong with it - an expensive mistake.
So the plan was for me to take out all of the injectors, clean them and make a note of the codes so we could recode the car...as it is a 2002 we cannot read the codes only enter them. It was sods law when I deicovered that the white reconditioned code stickers on cyls 1 and 2 on the block have worn and the codes are unreadable. So I'll be taking those two injectors to the local Delphi place for recoding then we will try it again,
If we need to do it on a cold car, I'll leave it at Peters house over night so we can have a crack in the morning.
never easy...is it? :)
PS My EGR Valve is at the front of the engine - nearside. There was no cooling assembly to disconnect or drain - the EGR has 3 ports - from intercooler - to engine and from exhaust I just disconnected the pipes and removed the EGR and the intercooler which was full of gunk.
#10 ·
Hi Rich,
It looks like I was a great hindrance and your mechanic was right. Sorry about the wild goose chase.
Peter
#9 ·
Mine had p2339, cylinder 4, we worked on the premise this meant cyl2, 4th to fire, this did not clear the fault, we recoded cylinder 4 , inj 3 on fordiag , the code cleared, so I would double check the codes, they should refer to the physical pot, 1 being drivers side.
this would make p2336, cyl 1, 2337 , cyl 2, p2338, cyl 3 and p2339 is cyl 4, closest to passenger side.
Have to be very careful about the cyl and inj no.s
#11 ·
shouldn't be so hard on yourself peter, we can't all be right all the time.
It is a confusing set up with all the different references to inj or cyl.
Just hope you get it sorted, am hoping the coding when cold isn't crucial.
#12 ·
Lol, doesn't really matter Peter as we were planning on resetting all the codes on all the injectors anyway. Your approach is sound.
Only question is, if it is the 4th on the block that is playing up then why is the fault still showing when they have replaced the injector with a new one? I can only assume that they recorded it and the ecu dropped the new code?
Any ideas?
#14 ·
I read Scooters post again the top post .. and whenever i hear excessive white smoke and lumpy idle ..immediately three things spring to mind . shot injectors or pump giving low pressure ..[have a complete fuel system check.]2, bent con rod . ..[do very thourough pressure tests on all four cyliders.] 3 .Chain timing has slipped due to the timing chain having jumped .[check engine timing chain timing] these three thing must be cheked . on this motor ..its a problem motor but unless you have these checked and cleared .. like banging heads off stone walls. s
