Ok, I've got all the bits I need to do this now.
2 x 45cm smd led strips in white. ( Already fitted - see HERE )
2 x 45cm smd led strips in amber. LINK
2 x 12v spdt relays. LINK
2 x UF4001 diodes. LINK
2 x alum electrolytic capacitators, not sure what value to use yet as I'm going to experiment.
Wire, 2 different colours.
The white leds I already have installed are stuck to the top of the bumper, underneath the headlight and as far back as I could get them. The plan is to stick the amber ones either directly infront of the white ones on the bumper, OR on the bottom of the headlight as near to the front as I can get them. Trick is to get it so neither are visible when not in use.
As it is the white one you can't see when turned off ! I want the same for the amber one.
Going to try a few positions now before I start the installation.
Heres a pic of the white ones, on and off :
