drivers side heated screen not working
7.6K views 20 replies 5 participants last post by  Marpheous
#1 ·
my drivers side heating screen doesnt work its not a fuse i checked them. passengers side works fine. odd thing is theres a couple of chips passengers side so i could understand if it didnt work but drivers side hardly a mark.
where should i be looking for the problem now?
#2 ·
connectors to screen, take black plastic trim(s) off, unplug and plug in a few times, mine was loose and the wiper mech was hitting it everytime wipers went past.
#3 ·
ok cheers ill have a look when i get chance
#4 ·
if that don't work, accidentally throw a brick at it, and call for a windscreen.
#5 ·
Good advice
#9 ·
under the trim pannel where the window wipers rest. think of the area when you change the pollen filter and you will get the idea. often worth unplugging the relays and reseating them. dont forget that they sit idle for most of the year. one connector per siide on the bottom corners.
Worth trying a gray ford relay in the socket to check that the control side of things aint wonky (yes rich we will have a look at your's )
Tim
#11 ·
Tim
I knew you wouldnt forget
#12 ·
i got to change the pollen filter anyway so ill take the relays out and refit them.
#14 ·
where is it? pollen filter side or other side?
#16 ·
ah i thought u might say that, is it possible i could reach it through passenger side? i got long thin arms lol.
just dont wanna be out there in this weather for long with my health probs.
#17 ·
windscreen connectors on mine were near each end of the screen, prob wont be able to reach.
#19 ·
bugger
ill have to try the bits i can reach and hope it works if not just need to wait till its warmer
#20 ·
#21 ·
as siruncle said.
I think i spent max 1 hour that included me cleaning the lower end of the screen of dirt and crap... as well and a little spit and polish on the plastic trim, then cleaned up the connection points and greaced them to aid if they need removing in the future.. all within an hour easily from start to finish >)
