Hi Folks ,
I have a question .. I'm driving Focus 1.8 tddi 2001y. I have problem with the heating in the cabin . When I turn the regulator on hot , then is not blowing hot in the cabin . On cold is working fine , A/C also is working fine just don't have a hot air . I though that the heather core is blocked somewhere, so i do Flush a lot of rust come out but no result
even become worst now i don't have hot air at all. Also the engine need long time like 10-15 minute to became in working temperature. After that I open the coolant tank and I check the temperature of the coolant inside with my finger it was totally cold, not warm at all . Does anyone of you know the problem or can help with some advice what to do. The outside temperature at the moment is -3 C and I'm freezing when I need to drive ....
Is it possible the thermostat to be stack open all the time ?
Thanks a lot in advance
Greetings to all
Greetings to all
