Hi all,as you may or may not know i have just had a bit of a headache,with having a new dmf and clutch kit installed,
when they put the slave in on thursday,i could not select any gears,at all,and there was a bloody big pool of fluid on the floor,and all over the top where the slave bleed nipple is. anyway
they sorted that out and replaced,the new slave with another new slave,i can now get all gears and it is very smooth,and you only have to lift the pedel off the floor about an inch before it bites,i picked this up on fri morning about 9.30am,and have been driving around with no problems,i had a quick look under the car on sat morning and see this,
Now does this mean i have a leak in the second new slave,or is it the old fluid from the First slave leak???Finding its way out of the bellhousing???? I still have full clutch function...
Your opinions please..
