Overcooling.....arrrgh!
1 reading
492 views 1 reply 2 participants last post by  salta
#1 ·
I've read many posts on the Mondeo Mk3 TDCI overcooling problem. I have all the symptoms, hot then cold with heater on etc but I'm not looking for a simple answer as I don't think there is one. What I do need help with is checking whether the cylinder head temp sensor is working properly.
Can anyone tell me what I should expect to see if I stick a meter across the terminals a) when it's stone cold and b)at normal running temperature.
Ok, as I'm here I may as well ask about an additional symptom my car has. When I start from cold the car rattles like 1970s diesel Transit. It feels like it is almost in "limp" mode but there is no flashing glowplug light. I drive for a few miles until it warms up (still rattling all the way), at a convenient point I stop and turn the engine off and on again and hey presto it's fine, quiet and smooth.
My reasoning is that the temp sensor is giving engine management a wrong signal at start up that saying the engine is warm so the engine runs lean hence the psuedo "limp" symptoms. When I restart, the engine is warm so engine management is happy.
Does that sound plausible?
Thanks,
Zane.
#2 ·
the first problem of cold start issue is usually to do with the ecu and not the cht . and requiers a cold start remap or patch at a main stealers. I dont have acess at perset to cht wiring and im answering you because your post has not been answered .
the second issue is to do with the main thermostat most likely . not haveing much to go on re your post . heating and cooling I will just say that this problem is usually caused by one of these .. the wrong stat is fitted . . It needs a ford speck stat and more importantly the proper ford seal to seal the stat in its well .as spruious seals will allow coolant to seep by the stat . .. 2 . a new stat has been rongly fitted . . 3 somebody prior to present owner has removed the stat entirely . 4 ,, the oil cooler stat on the coolant pump needs replacing also .. s
