hit a problem. I have the motor up on axel stands at the minute. Started work fitting the koni suspension kit i have, passenger side 1st. all was going well until i got to the pinch bolt on the rear knuckle. Bloody hard to loosen but it started, and then it snapped :tonofbricks: . had to drill it out on one side to release the strut end. i then moved on the the front passenger side and the pinch bolt is just as tight there. before it broke i gave up until i get some advice.
Q: how can i remove the pinch bolts with ease? any tips will be well appreciated.
