61 - 80 of 146 Posts
When connecting to module, ForScan wishes to download some firmware from internet. Is that safe? On the other hand, it doesnt idrntify as DW10C anywhere, but it says Stage V. Maybe enhine markings were different for some markets?
Here are 2 pics on what needs to be done.
1. Get a good ELM327 with HS/MS switch or even better a VCM2 that supports module programming
Open Forscan , make sure you have got the extended license (free right now on their website , follow guide there).
Open configuration menu (the icon of a QFN chip) and choose BCMii config (main config) change to engine type as in the picture and write back to BCM and IPC (back up module). The operations are done by pressing the play button.
after this is done choose to reinit the PCM.
Also make sure to do a full DTC read and erase because you will have sonme U codes.
Hope this clears things up for you guys.
What a good ELM327 (with HS/MS of course) do you reccomend to do this?
do you checked it on any ELM327?
Discussion starter · #67 ·
I use VCM2 so cannot recommend any ELM but look on ebay and try to find a seller that guarantees 500+ kbps and you should be fine (my old cheap elm from china does max 250 kbps and works fine with programming but since I have a VCM2 the elm is not used any more)
Maybe this one - ELM327 V3 STN1110 or STN1170 - https://viaken.pl/allegro/images/images/elmvsstn.jpg
But I doubt if it will work, because on my cheapest ELM327 HS/MS not detected BCMii, IPC, RCM module in Forscan.
What do you think about it?
https://s.click.aliexpress.com/e/bL14XEDS
Also, I tried 140 version, and it seems much better, more responsive on low rev's, where you spend 99% of the time. So I hope you won't be dissapointed.
I bought very speed ELM327 with auto MS CAN / HS CAN switch. But still can't enter to PCM, and still don't show BCMii. Others modules working and I can enter to configuration.
I make photos from my Forscan - can you look?
And I check ELMconfig - also everything working, but don't show BCMii and is problem with PCM. Look on the photos.
https://ibb.co/pbXv4T2
https://ibb.co/878D4PZ
https://ibb.co/zNjmnzn
https://ibb.co/TqrGQZP
https://ibb.co/h7Bc7gD
https://ibb.co/Nrx2T9C
https://ibb.co/ckQxFVs
https://ibb.co/YNvFtn7
Please help... this is very important for me :(
Discussion starter · #79 ·
The error is security access (missing bootloaders) or something else that I don´t know. I think you will get better help on Forscan forum where the developers of the program are present.
Try an older version of Forscan if you can find it.
