just thought i write a How to Replace the
TDCI Aux Belt Tensioner
The kit that i got was made by gates and cost me the total of £105 inc vat part number is k036PK1640 and was purchest from Unitpart
Tensioner/Belt/3 Pullys
Tools for the job
Wheel Brace / Trolly Jack / Axel Stand / Wood.
Sockets
8mm/10mm/13mm/15mm/18mm + Extender Bars
Spanners
13mm/15mm
Torq's Bits
T40 and 10mm allen Key
1 loosen the wheel nuts then jack up the car so the wheel is off the ground and support the car with the axel stand . take off the wheel completely ...
in this Picture you will see a dirt cover that needs to be removed using your 8mm & 10mm sockets remove the
Now you need to jack up and Suport the engine with some wood using your trolly jack see picture
Engine mount removel it would be wise to move the water header tank using 10mm socket on extender now remove engine mount using 10mm Socket for the Sound deadner 18mm for the Top Nuts and 15mm for lower Bolts See Pictures
Now when lowering the engine becarefull not to damage your CV Joint as it can rest on the subframe
Now you can eather Pull of your belt or cut it REMEMBER how it goes on !!
Now to remove the Tensioner you need to undo the altenator using 15mm socket on the bottem Nuts and 13mm socket on the top bolt
Now comes the removel of the Belt Tensioner
3 13mm Bolts hold the frame on 2 from under the car other at the top
Getting it out is a little tricky i had to push the altenator up high from under the car and take the Tensioner out beside the exhaust pipe
Now you can Repace parts using Torqs T40 and your 10mm Allen key
Removing center Pully you will have to take the remainder of the engine mount off 1x 13mm Nut 2x 18mm Bolts 1x 15mm Twin Ended Bold that holds the center pully
Remember when refitting that the Belt goes through the Tensioner
i made a little tool for releasing the tensioner so the belt can be put back on the pullys with no Fuss
i used a 13mm bolt and 2x 13mm nuts i did have to File/Grind to small flat spots so it would fit in the 1/2" hole i used a spanner to Lever
Hope this helps
Cheers
Mark
Tools for the job
Sockets
Spanners
13mm/15mm
Torq's Bits
Hope this helps
Cheers
Mark
