(A second attempt at getting some answers from this forum. Moderators: If you want you can delete the previous thread from yesterday: http://www.talkford.com/community/topic/244753-noise-from-a-pulley-or-auxiliary-belt/)
Hi all!
A couple of weeks ago I replaced the auxiliary belt, tensioner pulley, and idler pulley on a Mondeo MK3 1.8L (pre-facelift, 2003). Lately, I have noticed a persistent "tapping" sound produced somewhere in the aux. belt area. The sound is quite obvious when idling on low RPMs.
Having had a hard time pinpointing exactly which pulley is causing the noise I tried to record a video to get some help from the forums. Hopefully I can get some pointers on whether the alternator, water pump, power steering pump, crank shaft pulley, or the AC compressor is about to call it a day.
There are two versions of the same video. One has the original sound recording with the ambient engine noise. The other has the "tapping" sound enhanced (with a questionable degree of success).
Please take a look and listen carefully (preferably with a pair of headphones) if something seems clear to you I can go after:
Filtered and enhanced:
Original recording:
Hi all!
Original recording:
